I am trying to run daq mxBase 2.0 on SUSE 10.1, kernel 2.6.16.13-4-smp, 32-bit x86. I installed NI-KAL 1.3 without any errors. The DAQ mxBase installation found version 1.3 of nikali during the installation and finished again without any errors. But lsdaq detects no cards althought lspci shows the presence of two PCI cards correctly as shown below.
01:00.0 Class ff00: National Instruments PCI-MIO-16E-1
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV+ VGASnoop- ParErr- Stepping- SERR+ FastB2B-
Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR-
Latency: 16, Cache Line Size 10
Interrupt: pin A routed to IRQ 217
Region 0: Memory at feafb000 (32-bit, non-prefetchable) [size=4K]
Region 1: Memory at feafc000 (32-bit, non-prefetchable) [size=4K]
01:01.0 Class ff00: National Instruments PCI-6052E
Interrupt: pin A routed to IRQ 225
Region 0: Memory at feafd000 (32-bit, non-prefetchable) [size=4K]
Region 1: Memory at feafe000 (32-bit, non-prefetchable) [size=4K]
The following kernel modules also appear to be loaded
nipxirmk 127700 1
nidimk 332200 2 nipxirmk
niorbk 134196 2 nipxirmk,nidimk
nipalk 1253744 5 nipxirmk,nidimk,niorbk
nikal 63316 3 nipalk
usbcore 116612 4 nikal,ehci_hcd,uhci_hcd
Running mxbaseconfig fails with the following error
Can't load LabVIEW runtime library /usr/local/lib/liblvrt.so.8.0
libOSMesa.so.4: cannot open shared object file: No such file or directory
Has anyone else seen this with Suse 10.1. Is the kernel not yet supported? I'll be happy to post more informatin as necessary.
Arvind
