10-16-2008 04:47 PM
Is there an analog output and input module that I could use to program 4-20 ma under control of Signal Express. I would like to drive a device for 3 seconds at 12ma and three seconds at 20ma. I would also like to take an analog sample during each state. If I purchase the right hardware, can SE do this without having to do any programming in LV.
thank you,
john
10-17-2008
02:45 PM
- last edited on
05-03-2024
11:53 AM
by
Content Cleaner
Yes you can do this in Signal Express. If you get stuck on this please post back and we can help.
To get 4-20mA current output you will need one of these:
4110 For PXI and a lot of current output https://www.ni.com/en-us/shop/model/pxi-4110.html
4130 PXI https://www.ni.com/en-us/shop/model/pxi-4130.html
6704 PCI or PXI https://www.ni.com/en-us/support/model.pci-6704.html
9265 cDAQ https://www.ni.com/en-us/shop/model/ni-9265.html
None of these can do analog input, but there are TONS of choices depending on what you need for that. Would you just be taking one sample? If not what rate?
