Multifunction DAQ
ni 9265 wiring and VI (cdaq)
I am using a ni 9265 analog current output with a cdaq 9185 to control a small 4-20 milliamp driven valve.
I haven't successfully got it to output current yet, I was hoping I could get some help to verify I am doing things correctly:
wiring:
1. +24 V from power supply to Vsup on module
2. ground from power supply to COM on module
3. wire 1 from valve to AO1
4. wire 2 from valve to AO2
VI: (see attached)
1. DAQmx create channel AO-current-basic outside while loop
2. inside the while loop DAQmx write analog double 1 channel 1 sample
3.control wired to the data input that ranges from .004 to .020
I set up the task for analog output current for the module in measurement and automation explorer.
Thanks!
(1,003 Views)
For further discussions cf. this parallel thread
Kudos are welcome...
(964 Views)
Sorry, typo in my original post by mistake:
3 & 4. the valve was wired to AO0 and AO0 ground
(948 Views)
