Multifunction DAQ
ni-9237 damaged
I have a module ni 9236 damaged, sn-HB6399178, recently acquired, which is not recognized by the CDAQ-ni-9184, by Cryo-9102. When I run the program MAX recognizes the system, but not the module. To help identify the problem, I note that, when I attach the module in the CDAQ, the tension between the inputs EXC and RC is zero. How should I proceed to solve the problem Beste Regards Armindo Lage
(3,393 Views)
Hi alage,
Thanks for posting your question on this forum.
Have your ni 9237 already worked before ?
With ENET Daq you have to add your device in max manually. In the attached screenshot , you will find where is this button.
Could you give me more information about your problem and your software configuration ?
If your devive is really out of order, you must call the National Instruments technical support to repair it.
Regards
(3,361 Views)
