03-02-2006 02:36 PM
03-03-2006 02:05 PM - edited 03-03-2006 02:05 PM
tsingle,
I would suggest that you try the DAQ Diagnostic Utility available here:
http://digital.ni.com/softlib.nsf/websearch/FEA4D55E1B3DA33A86257076006AA260?opendocument&node=132070_US
If this test passes the analog input test you might have a problem with your
SCB-68. If you are using the 6224 you should have two connector blocks
(two SCB 68s). Have you tried your second SCB-68?
If DAQ Diagnostic Utility reports any failures, or if you have tried the 6224
with different cables, and different SCB-68s the only other test you could try
would be to put the card in another machine. If all of these tests fail, you
probably have a problem with your card. If you would like to talk to a customer
service representative about having your card repaired you can call (800)
531-5066.
Jesse O.
Application Engineering
Message Edited by Jesse O on 03-03-2006 02:05 PM
