Multifunction DAQ
need help to get started with 6320
I have got a PCIe-6320 recently and I haven't succeed to use it for counting purpose. I input TTL signals to pin 37 and I try to see some count numbers from counter 0 but I always get nothing. The DAQ board was installed properly.  But I can not read any number from the counter. I run example VIs like Count Digital Events.vi and Count Digital Events-Buffered-Continous-Ext Clk.vi. I connect only one signal to the connection box SCB-68: the signal to pin37 and ground to pin 4. What other test should I do to figure out the problem?
thanks.
Lixin
(2,825 Views)
Accepted by topic author LCHEN5154
problem solved.
(2,809 Views)
hi...
how did the problem fixed.?kindly let me know.I have an issue in generating the pulse train through counter ,as well as i couldnt count any pulse as you faced.
(2,504 Views)
