i got confused when i tried to configuer my sensor in Max. coz the diagram tells me to connect the output to pin 68 and a ground pin. but my sensor has only one output. i connect it directly to pin68, leaving the ground pin empty. i recieve no result from the test pannel.
btw: i'm using pci-6251 and scb-68
it's a rookie question. can anyone gives me a hint ?
thanks in advance
Message Edited by yonderstar on 09-08-200508:49 AM
