04-11-2010 03:01 PM
04-12-2010 04:59 PM - edited 04-12-2010 05:01 PM
Hello amz23,
In order to best answer this question, I'm assuming you will be using a digital encoder to measure pulses to obtain angular velocity (in RPM) for the blade. If so, the NI BNC-2120 interfaces with our X Series, M Series, E Series, S Series, and NI 671x devices. These devices have counters e.g. to measure velocity (for example rotational speed of a shaft) you will need a signal proportional to speed, squared and in TTL/pulses standard to input to the counter. I have included a link (1) with more information on the BNC-2120 and a detailed list of the different device series mentioned above (see left pane of the page). To learn more about counters/encoders, see link 2 below of the M Series User Manual, Chapter 7 on Counters; or search "encoder" at www.ni.com for tutorials and LabVIEW examples on these measurements.
1. NI BNC-2120: http://sine.ni.com/nips/cds/view/p/lang/en/nid/10712
2. M Series User Manual: http://digital.ni.com/manuals.nsf/websearch/2025C99AB0614F9E8625748000577B9A.
Ali M
