‎06-21-2006 05:19 PM
‎06-22-2006 11:50 AM
Hi Jacob,
Did that error come with any text? Most commonly, it means that a VISA session could not be opened. NI-DAQmx Base uses VISA, but I'm not sure why you may be getting this error.
Have you verified that your USB-6009 shows up in the List Devices utility? Also, can you run that example program you referenced without any errors? If so, can you point out any differences between your code and the example program in terms of the DAQmx Base programming?
Laura
‎06-22-2006 04:12 PM
‎06-23-2006 05:17 PM
