06-21-2006 05:19 PM
06-22-2006 11:50 AM
Hi Jacob,
Did that error come with any text? Most commonly, it means that a VISA session could not be opened. NI-DAQmx Base uses VISA, but I'm not sure why you may be getting this error.
Have you verified that your USB-6009 shows up in the List Devices utility? Also, can you run that example program you referenced without any errors? If so, can you point out any differences between your code and the example program in terms of the DAQmx Base programming?
Laura
06-22-2006 04:12 PM
06-23-2006
05:17 PM
- last edited on
04-13-2026
10:06 AM
by
Content Cleaner
Hi Jacob,
Could you follow the instructions in the Getting Started with NI-DAQmx Base for Linux and Mac Users
Let us know where things start to break down for you.
