06-26-2012 09:41 AM
I want to make sure I have the latest device drivers and DaqMX software on my Win7-32bit systems.
The support download page has both NI-DAQmx v9.5.1 and NI Device Drivers v2012.02.
Does the DAQmx v9.5.1 include the drivers from NI Device Drivers v2012.02? Or do I have to install both of these?
Thank you very much,
buddy
06-26-2012 09:47 AM
Your question is backwards. A device drivers distribution includes DAQmx, NI-VISA, etc. Not the other way around. If all you need is DAQmx, then just download that and install it.
06-26-2012 09:55 AM
Thanks for your answer.
Ni Device Drivers v2012.02 says it contains DaqMX v9.3.5.. If I want the latest DaqMX v9.5.1, I think I still have to install both.
buddy
06-26-2012 10:23 AM
If you want the latest DAQmx, then why would you do an install of something that is downlevel? You can certainly waste as much time as you want but I certainly don't see the point unless you need all of the other hardware drivers.
