I am a begginer of LABVIEW and DAQ1200. The problem is that i can't get any signal from a function generator, for example, a sinewave. I set my DAQ1200 card with differential analog input mode and use channel 0 as positive,and channel 1 as negative input. Must i connect the pin 49 and pin 50 to a voltage source to run the card? Besides, the readings i got by using Testpanel is either -5V or noise.
Hope those who know the answer can help me. Thanks a lot!
