Multifunction DAQ
i got a problem with my sampling rate
    hey everybody.
i got the following problem:
i use 4 analog input channels, i set the sampling rate to 10k and the number to read at 100. i record the data for a few seconds. after opening my .lvm file, i see that i got more than 400 values, every 1msec. it seems that my while-loop records contiuously.!?!
another example: i set the rate to 1kHz and the number to read at 200. after recording i get data every 1msec. some of the channels have read 100 values the others read contiuously. that means that i got empty lines in my file for some channels that appear every 100 lines for 100 lines. !?
i think for 200 values that i record with a sampling rate of 10k i should get 200 lines of data with a timestep of 100µsec. after this 20msec i should see a step in the timescale due to the while loop and than it should start from right again.
but it does not. so my question:
what have i done wrong? just entering sample rate and number to read leads not to the expected result.
my DAQ and my card can up to 1MHz!
thanks
(3,072 Views)
Hi billanator,
well, the reason that you get so much values is probably the fact that you have placed the VI which acquires the data in a while-loop.
If you set the sampling rate to 10kS/s and the number of values to read at 100 you will acquire exactely that. But since you're using a loop you will acquire that contiuously because your VI starts every iteration again till the while-loop stops.
Hope that helps.
Regards
Paul
(3,053 Views)
    thanks for your help. it was hard work but yesterday i found the bug.
it was the following: i got the data of some channels out of a case structure which was switched of 🙂
after turning it on i got the right number auf read data points with the right ratio at all channels for each iteration 🙂
thanks, billa
(3,039 Views)
