12-17-2007 04:23 AM
Can you convert the schematic Protel files to PDF or Postscript or ??
I cannot read the Protel files and I don't have a viewer.
12-18-2007 01:06 AM
Hi KC,
here itis in PDF
thanks
Rick
12-18-2007 03:49 AM
12-18-2007 04:28 AM
Sorry normaly I work with Protell there you click and You know it
You think just the IC'S should be Ok?
1) U1 = Winbond, W29C020C
2) U2= ICS, ICS9169M
3) U3= Geode, GX1 200B-85 1,8
4) U4= Maxim, MAX211EAI
5) U5, U6= Texas ins., LV573
6)U7= Geode CS5530A
7)U8 = Pulse PE-68515L
8)U9= National PC97317ICL/VUL
9)U10= National DP83815DVNG
10) U11 ST 93C46
11) U12,U13,U17 = LT, LTC1149 (3,3V 5V, 1,8V)
12)U14, U15, U18= Fairchild, FDS4559
13)U16 = Maxim, MAX6357LSUT
14)U19 = Texas Ins. TPS2211
15)U20= Philips, 74HCT138D
16)U21= Dallas DS1621
17)U22= Texas Ins PCI1510
18)U23= M-System MD-2810-008
19)U24= Philips, 74HCT139D
12-18-2007 04:37 AM
12-18-2007 05:22 AM
OK, I will have a look at it all.
What is the link with NI ?
12-19-2007 04:47 AM - edited 12-19-2007 04:54 AM
Hi Rick,
The last link you posted is for an AMD proc. I don't know if it compatible with the NSC proc.
This means that you don't have a tool to verify that the BIOS prom (U1) is programmed correctly ?
Do you have a keyboard/monitor attached. Is there any output ?
If not, for a start can you verify that the boot proces is started after a HW reset by measuring the #CE (pin 22) signal MEMR# (pin 24) at U1
12-19-2007 05:38 AM
Hi KC.
Bios should be all right as we got one working Unit and we swapped the Bios Chip and works fine we tried all Program IC's all seem to work fine on the working unit.
We don't have a Display as it is normally just used as a satellite in a Network.
NS sold Geode to AMD so this link was from AMD for debugging and maybe programming the GX1?
As we think that there is a small program on the Processor GX1
We will try to swap the GX1 but waiting for the Reball station as it is a BGA
Rick
12-19-2007 05:50 AM
Normally I would not start replacing components before you are sure that it is necessary. But when you are desperate.....................
If you don't have a monitor connected how do you observe that the board is working or not
What OS runs on the disk ?
12-19-2007 11:55 AM
