Dear Sir:
I am using create file.vi, write file.vi and close file.vi to generate my report in .txt format.
Since the input of the write file.vi is string, I used "Array To Spreadsheet String" to convert my array data.
I have several issue for this application.
1. For "Array To Spreadsheet String", the default delimiter is tab. Can I change the tab width in labview?
2. I try to change the data font in labview, however, when I save to .txt file, the font are always kept as default font. Can I change the font of data to save into .txt file.
3. When I try to use report generation function of labview, I just can save file as standard format, word, excel, and html. How can I save file as .txt file by using report generation function?
4. When I save report as excel file, I have some issue that I can not solve it. I already post it on the board as link below, but got no response. Welcome for any suggestion or experience. http://forums.ni.com/ni/board/message?board.id=170&message.id=125000#M125000
Fred
