03-16-2009 04:36 PM
Hi, I have Labview 8.5 here connected to a USB-9234. We are trying to use accelerometer which need to be configured as IEPE, I tried as one post in this forum: http://forums.ni.com/ni/board/message?board.id=100&message.id=1976&query.id=143505#M1976
but I can't find it in the Labview signalexpress neither when I browsed as the address in that post.
Here is my searching addess: C:\Program Files\National Instruments\LabVIEW 8.5\vi.lib\DAQmx,is that right?
03-17-2009 09:44 PM
Hi Lester14,
To configure your accelerometer as IEPE, you'll want to do this from within LabVIEW rather than trying to navigate to it through C:\Program Files (you'll need a property node which cannot be easily navigated to- the other forum post where this was mentioned is talking about using DAQmxBase which uses VIs to set this property rather than a property node). I think all the information you'll need is found in THIS KB. Let me know if you need more help!
03-18-2009 11:04 AM
