When using the express sine generation in fpga, lets say 50Hz, the frequency is round-off to some mHz .
So correct 50001 mHz generation is not possible with the express sine generator.
What is the best way to solve this?
My goal is to precisely generate frequencies from 0 to 60Hz in millihertz steps. Like a VCO or voltage controlled generator does.
The frequency should be addapted hundred times a second from the host. Like a sweep function.
Have program a realtime simulator for powerplants written in C++.I translates the RT sim to NI components and software (Labview).
My rt pxi turbine simulator for simulating grid incidents was succesfully used in a nuclear plant in 2006.
Look at http://sine.ni.com/cs/app/doc/p/id/cs-755
