Hello Yajai,
I would suggest using the WordReport instrument that ships with
LabWindows/CVI (<install
dir>\CVI80\toolslib\activex\word\wordreport.fp). If you open
the code for the WordRpt_SetFooter fucntion, you will notice that the
code shows how to insert text into a footer. To insert a image
into the footer, you should replace the call to Word_SelectionTypeText
with the following lines of code:
// Gets a handle to the inlineshapes object
Word_GetProperty (currSelHandleL, NULL, Word_SelectionInlineShapes, CAVT_OBJHANDLE, &inlineShapes);
// Adds an image
Word_InlineShapesAddPicture (inlineShapes, NULL, "", , , , );
For more reference, I would suggest searching MSDN. I also found the following website that demonstrated how to use
VBA to insert a barcode into a Word footer.
Also, as a final note, if you have CVI questions, I would suggest
posting to the CVI forums, since you increase your chances of getting
another CVI customer to respond to your post.
Hope that helps.
