04-09-2012 11:44 PM
hello, im trying to generate 2 Mhz frequency signal in labwiew software. but if i increase the frequency above 500 Hz it shows error "error 20061". plese find attachment with this post. n help me to remove the error.
04-10-2012 02:05 PM
It looks to me like the default sampling information on the square wave.vi is set to a sampling rate of 1000, your output will be limited to 500Hz. The frequency output of the Square Wave.vi is limited to fs/2. If I add a cluster constant for the sampling info and change the fs to 2000 then I can output a 1000Hz signal.
Hope this helps.
Steven M.
04-10-2012 03:14 PM
You really are not going to get there with the PCI 6259. Yes is has an update rate of 2.8MHz. It also has a min rail-rail settle time of 2uSec. This mean if you start going above 250KHZ the output simply cannot slew fast enough and will be distorted and attenuated.
04-10-2012 04:57 PM
Jeff:
Would a high speed buffer or schmidt (sp?) connected to the output improve performance?
-AK2DM
