Translated to from Vietnamese to English (google translate). For better result, you should try to post in English)
A simple hope LABVIEW (5.1) DAQ question from a newbie: I need to enable a D / A converter's digital channel Different signals each 50 milliseconds (Signal length <4096 samples, using PCI 6111E board in a 400 Mhz Pentium). I create and store different signals in a 2-D array and use Finite Pulse Train.vi as a first attempt at a trigger signal. The VI examples and documentation available do not make it clear how to Repeatedly and continuously activate the D / A converter over time. Have any Is there any example there or documentation on how to do this? Any help will Very much appreciated !!
LabVIEW 5.1 is 20 years old, probably the age of that computer (what's the OS?). You also need to use traditional DAQ drivers (DAQmx is not compatible). I assume you have all the software and drivers installed. Let's wait and see if some of the older users here can help you.
