Multifunction DAQ
how to configure other digital ports except port 0 of daq 6351 for acquiring digital waveform
sir,
i can acquire digital waveform using 8 line of port 0.but i have to get 24 bit digital waveform.So please tell me how can I configure other DIO ports so that i acquired digital waveform using those DIO line also
Message 1 of 8
(4,965 Views)
Accepted by topic author sathi
You should be able to create a DAQmx task to read Port0, Port1, and Port2.  When you read the data from DAQmx, you will then have to combine the array of port data as needed.
Message 2 of 8
(4,961 Views)
Keep in mind that the 6351 only has 8 hardware timed lines. Port 1 and Port 2 can only be read using software timing.
Steven K.
Software Engineer
Message 3 of 8
(4,956 Views)
Thanks for reply....can I triggered port 2 and port 1 using external clock signal...??Other thing is that,in X series Daq manual(page-121),it is written that other DIO inputs can be configured for waveform acquision,How is that possible???
please reply.its urgent
Message 4 of 8
(4,949 Views)
Page 121 (6-5) says "You can acquire digital waveforms on the Port 0 DIO lines." I have no idea what you are referring to.
Message 5 of 8
(4,940 Views)
@sathi wrote:
can I triggered port 2 and port 1 using external clock signal?
Based on Steven K's response, I would say no.  Ports 1 and 2 are only software triggerable which means that they only read when a program requests data from them.
Message 6 of 8
(4,937 Views)
Sir I want to refer following line...
You can configure each DIO line to be an output, a static input, or a digital
waveform acquisition input."
Here it is mentioned that I can configure each DIO line to be Digital waveform acquisition..How can I do this???
Message 7 of 8
(4,929 Views)
Thanks for your reply...
will u please give a block diagram of what you said..then it will really helpful to me.
Message 8 of 8
(4,926 Views)
