hi,
i have a PCI 6110 device. i need to measure appx 15V on channel 1. however my "DAQ_DB_Transfer" seems to measure only 9.9V. i realized that this is the same value that i get in MAX software when "high input limit" is set to 10V. i notice that in the MAX software when i change it from default 10 V to 20 V i get the right reading i.e. 15V. but i need to do this in software from my program in VC++. what would be the Ni-DAQ function to use for changing the input limits?
i tried "AI_Configure(1,1,0,20,0,0)" but nothing seems to happen. i doubt if this is the function to use. what would be the right call that i would have to make?
thanks in advance,
mukesh
