10-27-2009 09:51 AM
how do i determine how much memory my pci-6115 has?
I see two memory ranges in NI-MAX.
Does my PCI-6115 have 32 or 64 MB memory?
Memory Range 1: FE9F7000-FE9F7FFF
Memory Range 2: FE9F7800-FE9F8FFF
Solved! Go to Solution.
10-28-2009 11:22 AM
There are a couple of ways to determine this. You could look for the sticker with the part number on the card. If it is part number 778534-01, then it is the 32 MB version; alternatively, part number 778554-01 is the card with the larger memory option.
The other way to check is using a property node. For more information, look here.
-Christina
10-28-2009 03:50 PM
Thanks, but I do not have a 7785...part number.
Here is my part number: 184529D-01. Note there are also, two memory board installed, both have part number 186612B-02.
10-29-2009 09:48 AM
That is an older part number for the the 32 MB board.
-Christina
