If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
Multifunction DAQ
how do I get LabVIEW to output to a oscilloscope
Okay, I got LabVIEW to output with the continuous generation vi. I'm using a SCB-68 connector block and a Tektronix scope. Now I want to use the function generator vi but I get the error "10007 occured at AO group config". I'm using the same channel configuration as before but for some reason no luck this time. Any ideas??
(2,698 Views)
I will try to help; however, I need more information. What hardware (AO) are you using? What is the ouput configuration (Channel,rate,...) for use with the function generator vi?
(2,698 Views)
Check the device number and ensure that it is the same as set by Measurement And Automation Explorer. Also check the AO channels and ensure that they are not out of range. If the AO channels are 0 and 1 and if you set the AO channel to 2, you will get such error.
I just ran the same VI and it worked fine.
Also, in MAX, check that the device is passing the tests.
Sincerely,
Sastry V.
Applications Engineer
(2,698 Views)
