From 11:00 PM CST Friday, Feb 14th - 6:30 PM CST Saturday, Feb 15th, ni.com will undergo system upgrades that may result in temporary service interruption.
how do I get LabVIEW to output to a oscilloscope
Okay, I got LabVIEW to output with the continuous generation vi. I'm using a SCB-68 connector block and a Tektronix scope. Now I want to use the function generator vi but I get the error "10007 occured at AO group config". I'm using the same channel configuration as before but for some reason no luck this time. Any ideas??
(2,394 Views)
I will try to help; however, I need more information. What hardware (AO) are you using? What is the ouput configuration (Channel,rate,...) for use with the function generator vi?
(2,394 Views)
Check the device number and ensure that it is the same as set by Measurement And Automation Explorer. Also check the AO channels and ensure that they are not out of range. If the AO channels are 0 and 1 and if you set the AO channel to 2, you will get such error.
I just ran the same VI and it worked fine.
Also, in MAX, check that the device is passing the tests.
Sincerely,
Sastry V.
Applications Engineer
(2,394 Views)
