Multifunction DAQ
high speed storage system design
Very sorry if my question sounds not smart but i have been searching about available data-loggers and it was very strange for me that almost all of them have a low speed (few hundreds Hz at most).
e.g. if there is an 8 channels 10Khz 16bit datalogger, it would require the rate 10K x 8ch x 16 bits = 160KBytes/s of sampled data, so SD 2.0 class 2 can achieve this speed  easily (its write speed is at the minimum rate of 2MBytes/s.
1-maybe the power consumption impose low frenquency to save energy if datalogger is self-powered?
2-or the data processing handled during logging (i.e. AD conversion, filtering..) consumes more cycles than storing cycles which would cause a low frequency logging.
i will appreciate any help.
Thanks.
Saad.
Message 1 of 1
(2,732 Views)
