04-28-2007 11:53 AM
04-30-2007 10:11 AM
Why Do I Get a Measurement & Automation Explorer (MAX) Database Connection Error?
http://digital.ni.com/public.nsf/websearch/B9107A7F281F9B408625720B0078E5A8?OpenDocument
I would recommend starting here. If the problem persists, I have an additional question for you. Did you ever install any version other than DAQmx 8.5 on your Vista machine or any other drivers that are not supported in Vista? If so, this could point to a larger issue of which the solution is explained here:
How do I remove unsupported NI software from Windows Vista in order to install the officially supported versions?
http://digital.ni.com/public.nsf/websearch/B4BF3B96988453B98625728100009670?OpenDocument
Let us know how this goes. We would be happy to help further!
Brian F
04-30-2007 02:57 PM
05-04-2007 12:38 AM
05-07-2007 12:46 PM
I am getting in touch with our R&D department to see if there are any further troubleshooting steps that we can take to get this resolved.
Ed W.
05-07-2007 05:10 PM
lvsmith: Are you using the LabVIEW 8.2.1 or just 8.2? LabVIEW 8.2.1 is the only supported version for Windows Vista.
I am still waiting to hear back from our R&D department for more troubleshooting steps on this issue.
Ed W.
05-08-2007 10:00 AM
05-09-2007 11:42 PM
LabVIEW 8.2.1 is currently the only version to be supported with Windows Vista. Make sure that you have administrative rights on your computer. Otherwise, we have not found any cases where the problem was inherent to MAX – this error has only been seen to occur from other applications (firewalls, antivirus, security software, etc.) accessing the database.
As a troubleshooting step, try removing the computer from the network, and then shut down all possible security software. Once MAX is working, you should be able to narrow down the problem to a single piece of software, and then change the settings there to fix things once the computer is put back onto the network.
Ed W.
