09-03-2009 04:37 AM
I am using C# and MeasurementStudio to acquire continiously an analog signal with a USB-6229.
Sometimes I need to get N samples and sometimes I need to read all available samples on the DAQ buffer.
The code I use is:
public class AITask : Task
private AnalogMultiChannelReader reader;
public AITask(String name): base(name)
// Link a writer_csv to the task
reader = new AnalogMultiChannelReader(this.Stream);}
public void AddChannel(List<TestbenchChannel_DAQ_AIN> ain, double rate)
int N = ain.Count; for (int i = 0; i < N; i++){
//Create virtual trigger_channel in task
this.AIChannels.CreateVoltageChannel(channel.device + @"/" + channel.terminal, channel.channel_name,aiTerminalConfiguration, min, max, scaleName);
} // end for all AIN oracle_channels
//Configure the timing parameters
this.Timing.ConfigureSampleClock("", rate, SampleClockActiveEdge.Rising, SampleQuantityMode.ContinuousSamples);}
public AnalogWaveform<double>[] GetValues(int N)
N = (int)this.Stream.CurrentWritePosition - (int)this.Stream.CurrentReadPosition;
AnalogWaveform<double>[] wf = (AnalogWaveform<double>[]) reader.ReadWaveform(N); return wf;}
where TestbenchChannel_DAQ_AIN contains all the needed parameters to define the AI channels.
To read the sample, I am calling the function GetValues(int N). N > 0 for a finite number of samples or N=-1 when I want to get all available samples on the buffer.
Now the problem is that sometimes after a pause of 2s where I am not calling the function GetValues, a call to this function with N=-1 will return an array of waveform with no samples. Most of the time I am getting the available samples but sometimes not.
Why? Where is the problem? When I am using this function on a PCI-6014, it works!
Thanks for any help!
Risotto
09-24-2009 04:40 AM
Hi Risotto,
when you are saying that after a pause you do not get any samples back, do you get any error messages indicating e.g. a buffer overflow?
I am not quite sure why you are reading the current write position - this indicates the sample position for the output buffer.
Which DAQmx version are you using?
Peter
09-24-2009 05:53 AM
Hi Peter,
No I get neither error message nor exception. An I set the buffer to contains 30 minutes of measurements (I need it sometimes). And because I am usually reading the data each 2 seconds, the read position should be updated each 2 seconds.
On PCI-6014, this is working well. May be it is due to the communication with USB?
Anyway I have made an error copying the function GetValues and put some code I was using trying to solve my problem.
The right code is:
public AnalogWaveform<double>[] GetValues(int N){
wf = (AnalogWaveform<double>[])reader.ReadWaveform(N);
return wf;
With this code, I am getting the problem I explained in my first post.
Now after several tries, I found a - not nice - solution to get anyway the data:
AnalogWaveform<double>[] wf = (AnalogWaveform<double>[]) reader.ReadWaveform(N);int i = 0;
while ((wf[0].SampleCount == 0) && (i < 101)){
wf = (AnalogWaveform<double>[])reader.ReadWaveform(N); Thread.Sleep(1);i++;
return wf;
I am not really happy whith this because I don't understand what appends, but until now it seems to work.
Anyway I would be happy if you could give me some hints which could help me to understand the problem.
Risotto
