06-10-2015 06:55 PM
I need to generate two digital output triggers: for example, one trigger in channel 0 and the other in channel 1 with 0.25msec delay.
I'm using USB-6001 and looking for VC++ sample for a similar application.
Hyun
06-11-2015 06:17 PM
Hi Hyun,
C++ isn't officially supported by DAQmx anymore. You may be able to find some C examples in the DAqmx. Check out this knowledgebase article for more on finding those examples.
http://digital.ni.com/public.nsf/allkb/FB26BDA52FFFD4EE86257124005C36C3
06-15-2015 09:42 PM
Also, note, the 6001 does not support HW-Timed DO. Timing will have to be enforced by your computer, which will not allow for the level of precision you would get with and onboard clock.
