Multifunction DAQ
frequncy measurement usb 6221
actually (entey,date,time, speed)this string i want at the beging of the file but only at onces when file is created.
but this string is connected to binary file data that why when i run my program that time after one one reading that constant string also come
i want set that string at beging of file that means as header
its not work properly
tell me how to edit that program
Message 31 of 44
(1,879 Views)
I know you want it only once. You already said that and your original code was using the Write to Binary function. If you don't want to use that, then don't. And, I already told you how to edit the program - IN THE CASE WHERE THE FILE IS CREATED, WRITE THE HEADER.
Message 32 of 44
(1,871 Views)
thanks for reply me now its working
but one problem is that its not read contious data in file ,when file size 356kb then  its stop and error has come
what the maximum size of excel?
i think txt file have more capacity to store data than excel.
becoause every second i measure data and store it.
give me suggision may i change this txt format or excel also can store 24 hours data?
Message 33 of 44
(1,860 Views)
Older versions of Excel have a maximum of rows of about 65k.
Message 34 of 44
(1,849 Views)
hey i didn't find it its creating new file or not?
because before creating any new file it showing some error some read error
i attach that error please check it and give me any suggsion
Message 35 of 44
(1,826 Views)
No, I will not read a bmp file that you just renamed to jpg to get around the ban on bmp attachments. Do you really think that changing the extension changes the file type?
Edit - I had forgotten that I had said this before. Stop, really stop doing this. It is inappropriate behavior.
Message Edited by Dennis Knutson on 01-04-2010 09:21 PM
Message 36 of 44
(1,824 Views)
sorry dennis
well error 200278 has comes
its create file properly but after some time when file is 469kb it will generate error 200278.
Error200278 ocurred at DAQmx Read (Counter 1D DBL 1Chan NSamp).vi
Possible reason(s):
Attempted to read a sample beyond the final sample acquired. The acquisition has stopped, therefore the sample specified by the combination of position and offset will never be available.
Specify a position and offset which selects a sample up to, but not beyond, the final sample acquired. The final sample acquired can be determined by querying the total samples acquired after an acquisition has stopped.
Attempted to Read Sample: 0
Property: RelativeTo
Corresponding Value: Current Read
Position Property: Offset
Task Name: _unnamedTask<240C>
I READ ONE SOLUTION IN THAT WE HAVE SET  DAQmx timing IS CONTIOUS SAMPLE
I ALREADY SET THAT
Message 37 of 44
(1,816 Views)
hi any one is there
i send one error it has comes after some time
well you please tell how to correct it
i set continus sample but its not work after some time
Message 38 of 44
(1,799 Views)
HEY ANY ONE IS THERE MY PROGRAMS ITS WORK NOW BUT AFTER SOME TIME OR AFTER SOME RECORDS ITS CREATE ERROR200278.
I WROTE THAT I THINKS BUT NO ONE REPLY ME.
PLEASE GIVE ME ANY SUGGESION.
Message 39 of 44
(1,789 Views)
If you don't want to change to finite samples, then you should switch to a consumer/producer architecture so that the file write does not interfere with the acquisition.
Message 40 of 44
(1,787 Views)
