Multifunction DAQ
frequncy measurement usb 6221
ya i send you my vi in that its not cretaing 2nd file means i have to create file at midneight but its not creating whole informations store or save in one file.
then i place whole block in while loop that time data is not save file its overwrite.
what will i do data should save current date file and at midneigth it should to create other current date file and that time when you received that data it should to save that file
will you help please
Message 21 of 44
(2,017 Views)
what happend ?
no reply last 2 days
i asked some thing i think no one is there
Message 22 of 44
(1,997 Views)
Solution given here.
Message 23 of 44
(1,988 Views)
hi,
any one is there?
i attached my vi and error code
i have to create current date file at midneight but its not creating i don't know how to use shfit register
but i do one thinks , i use equal operator but its not work properly
will please help me?
see the my program and give me suggesions
Message 24 of 44
(1,925 Views)
What about the example you were given here?
Message 25 of 44
(1,921 Views)
i change some parts but when i run my vi some GPIB error has come
i attached that error and my vi.
plz help me
its working or not?
its creating file at midneigth or not that i don't know
plz help me
Message 26 of 44
(1,882 Views)
Do you really think that changing the suffix to jpg is actually changing the file type? There is a good reason that bmp files are not allowed.
p.s. The error message is pointing to 2 possible reasons - note the plural! Look into the first possible reason since you do not have GPIB.
Message 27 of 44
(1,865 Views)
Your code indicates that you've copied and pasted without understanding what the example program was doing. For example, the way you've done the comparison of the two dates and the greater than function is just silly.
I've made some changes and cleaned up some of the problems in your DAQ code. Give it a try. I would suggest testing the new file creation ability by changing the windows date/time instead of waiting 24 hours.
Message 28 of 44
(1,857 Views)
hi i checked ur modify vi its working
thanks ...........very muchSmiley Happy
but in that (entry,date,time,speed) that constant should be as hedar of file
only onces it's should to come at the beging of file but its also repeted when data has comes.
will you please tell me how to place constant hedar .
well happy new year to all of you Smiley Very Happy
Message 29 of 44
(1,828 Views)
You would simply write the header in the case where the file is created.
Message 30 of 44
(1,826 Views)
