09-23-2009 04:59 PM
I've been testing an app for the PCI-6224 on Fedora 9 (32-bit) and am building an instrument which is powered by a mini-ITX w/ Intel 330 atom processor. I thought I would try the latest (Fedora 11) while I was at it, but can drop back to 9 if necessary.
I cannot seem to install NIDAQ800_RedHat. When I...
mount -o loop /root/NI/NIDAQ800_RedHat.iso /mnt
cd /mnt
./INSTALL
I get the error...
Kernel source in /lib/modules/2.6.29.4-167.fc11.i686.PAE/source does not appear to be
configured for the 2.6.29.4-167.fc11.i686.PAE kernel.
There is a number of posts addressing this error, mostly centered on SuSe which call for 'make cloneconfig'. That is not present on Fedora. I haven't seen this before in the several times I have done this on Fedora (first on F7, then F9) and now F11. Could this be associated with the PAE kernel? Any suggestions?
John Navratil
09-23-2009 07:13 PM
I went a little further in following threads and found the suggestion to copy the boot config file over the .config in the kernel source directory. They were identical. Thereafter...
make modules_prepare
resulting in a failure with message ...
No rule to make target `missing-syscalls'. Stop.
09-24-2009 09:14 AM
Installed Fedora 10 with similar result.
Kernel source in /lib/modules/2.6.27.30-170.2.82.fc10.i686/source does not appear to be
configured for the 2.6.27.30-170.2.82.fc10.i686 kernel.
09-24-2009
12:51 PM
- last edited on
05-02-2026
12:04 PM
by
Content Cleaner
Hi John,
One good resource we have available for Linux-specific issues is the Linux Users Community Page. The community is made up of a number of developers and Linux users who work with NI products. Perhaps somebody there could offer some more insight.
I wish I could provide more advice but I have never tried installing DAQmx to Fedora before (keep in mind that it is not an officially supported distribution).
Best Regards,
John
09-24-2009 02:59 PM
John,
Thanks for the heads-up on the new (to me, anyway) community. I think I've found the core problem... I should be using the new (to me, anyway) DAQmx801f0.is, rather than the older NIDAQ800_RedHat.iso.
I'll write up my solution in the Linux Users Community when I've tested it.
-- John Navratil
09-24-2009 03:45 PM
Hi John,
I just realized I linked the wrong page for the Linux Community. Here's the correct link:
http://decibel.ni.com/content/groups/linux-users
