Multifunction DAQ
failed to read PWM signal generated by LabVIEW and DAQmx
Dear all,
I'm a beginner of Labview and DAQmx. I create a simulated NI PCI-6225 device and a virtual channel by using DAQmx. I want to use the counter of PCI-6225 to generate PWM signal, then display the waveform of PWM signal. I generate the PWM signal according to an NI example "pulse width modulation using NI_DAQmx and Labview" (http://www.ni.com/tutorial/2991/en/ ).
This example can't display digital waveform, so I add a DAQmx read module. Then there is an error " Error -200460. Read failed, because there are no channels in this task from which data can be read. Task Name: _unnamedTask<21>".
I tried different methods to modify the error, like add while loop, change sample rate, and so on. But, these don't work.
The problem may be simple, but because I'm a beginner, it's confusing to me. I've uploaded my .vi file. Hope to get help from you. Thanks a lot.
(2,262 Views)
Hi Euni,
Does this device work in the original example? Did you only start to get the error when you used your modified code? Are you able to create a different task -- as in, is this isolated to just the Counter Output from the card?
Hope this gets you moving in the right direction!
Erika
Technical Support Engineer
(2,205 Views)
