Multifunction DAQ
example for ni-4350
I have a DAQCard NI-4350 (PCMCIA) and am trying to program it.  I am running LabView 7
I went to the NI Code Exchange and searched for NI 4350.  One of the examples I found was “Maximizing Acquisition Rates with the NI 435X Data Logger Board Maximizing Acquisition Rates with the NI 435X Data Logger Board”.
After I downloaded the file and ran it during the loading an error came up.  The error is
Entry Point Not  Found
The procedure entry point –pkgModulePackageEventLog@20could  not be located in the dynamic link library NIPALU.DLL.
Can any one tell me what is going on and how I can get around it.
Most of the NI 4350 examples I found will not run after I down load them.
Thanks in advance,
John
(2,468 Views)
Hello, John!
When programming your 4350, it's important that you have the appropriate drivers installed on your system. In this case, you'll want the following: NI 4350 Device Driver
If you already have this, a re-install may fix the issue, since it should re-create the DLL in question.
If this does not do the trick, please let us know!
Will Hilzinger | Switch Product Support Engineer | National Instruments
(2,447 Views)
