03-18-2008 04:32 PM
Hi ,
i am getting problem in collecting data. i have an application called RADiAS which is on C++ ( VS2003) its using :
NI 7.5 version
MS2003
To trigger this app i am making another app in c++ (VS2005)and for this i am installing following software's on my system ( Windows XP) :
1. NI 7.5
2. MS 2003
3. VS2003
and after that i install the clients for the app RADIAS which is used for vibe analysis after collecting the data.
Having just NI 7.5 on the sytem, my app is working fine and i am able to collect data with the card DAQcard -6062E.But as soon as i install MS2003, i am getting the following error message:
AppName: radias_remote.exe AppVer: 1.1.3.1473 ModName: nicppaiu.dll
ModVer: 7.1.0.388 Offset: 00078f03
I am trying to install MS2003 to use the C++ libraries from it in my new app which is on VS2005.
so i need the info :
1.Is NI 7.5 + MS2003 + DAQ-6062E - is not compatible versions .what the error message means? if not then which version of MS i should I use with NI 7.5 and how to get it?
2. Can i include the libraries/ include files of MS2003 in VS2005 ? I cannot go to higher version of NI from 7.5.
so need a combination which will not affect the working of already build application RADIAS which uses NI 7.5 or lower versions with 6062E card. and also how to use libraries in my c++ program on VS2005 with that version of MS and NI 7.5?
I am waiting for the reply eagerly.
NI Software : Visual C++ version N/A
NI Hardware : Multifunction DAQ device DAQCARD-6062E
Driver Version : 7.5
OS : Windows XP
03-19-2008 06:04 PM
03-21-2013 09:41 PM
Hello
I can not execute an application developed with VS2010 & MStudio 2013.
Error detail is "There is no nicappaiu.dll to execute the application".
Please let me know how can I fix this error.
Thank you.
03-22-2013 11:29 AM
Hey sebastianminsuk,
This post is from 2008 and I think you would get more traffic if you posted a new thread. A new post also helps us track the issues so we can better assist our users. In the new post, could you include a general overview of your application (what it is supposed to do) as well as the file hierarchy that is associated with your executable? Are you trying to run the executable on a development machine or a deployment machine?
Thank you,
-KP
