I been trying to find the answer to this in the forum with no success.
The error code is well documented in the forums but none of the solutions apply to my problem.
I have attached the code based on the: Acq&Graph Voltage-Int Clk-SW Trig Restarts.vi example.
The error comes after 100 to 1000 readings. The shipping example get the same error when its not modified.
What i need in my application is to read th voltage from an ldr every 1 or 2 seconds the aquisition takes about 100ms and i have also put on infinite timeout. (samples to read: 1000, Hz: 10000)
I have had success with putting in an daq assistant, but i would like to not open and close the channel for every reading.
I realy hope someone have some suggestion for this. evt i would be glad if there is any alternative way to read a finite samples once a scond without open and close task.
Best regards
Fredrik
