Multifunction DAQ
disk drive power connector
Can somebody tell me that when (for what kind of applications may be) should we connect the device disk drive power connector in a PCIe 6353. In the device installion guide , its written "optional".
Thanks in advance,
Arijit
(4,313 Views)
From HERE
  1. (Optional) On NI M and X Series PCI Express devices, connect the PC and the device disk drive power connectors. The disk drive power connector is a 4-pin hard drive connector on PCI Express devices that, when connected, increases the current the device can supply on the +5 V terminal. For most applications, it is not necessary to install the disk drive power connector. However, you should install the disk drive power connector in either of the following situations:
    • You need more power than listed in the device specifications
    • You are using an SCC accessory without an external power supply, such as the SC-2345
From HERE
Current Limits
NI PCIe-6361/6363
Without disk drive power connector installed
P0/PFI/P1/P2 and +5 V terminals combined
  0.59 A max
With disk drive power connector installed
+5 V terminal (connector 0)
  1 A max 6
+5 V terminal (connector 1)
  1 A max 6
P0/PFI/P1/P2 combined
  1 A max
(4,303 Views)
I am also setting up pcie-6353. Unfortunately, I don't find any disk power connector in my Dell T5810 computer. I guess that I probably need to have an extension connector. Where should I get that?
(3,674 Views)
