Multifunction DAQ
daqmx version
Hi, I am running LabVIEW 2020 V 20.0, 32 bit.  What is the latest version of DAQmx that it will support?
(3,041 Views)
Accepted by topic author Jim_Marihew
Unless I'm misunderstanding your question, it looks like LabVIEW 2020 supports DAQmx versions 20.0 to 2022-Q4 (minimum).
(3,028 Views)
You can check out the compatibility here - https://www.ni.com/en/support/documentation/compatibility/16/ni-daqmx-and-labview-compatibility.html
In short, DAQmx >= v20.0 is compatible.
Santhosh
Soliton Technologies
(3,027 Views)
Generally, NI drivers will be compatible with a LabVIEW version that is 3 years prior.  If in doubt, check the readme for the driver version (DAQmx 2023Q3 readme).
But NI also had an initiative to make their drivers more agnostic to LabVIEW versions.  This started with 2022Q3.  We will see how long it takes for NI to decide to increase the minimum version required for these drivers.  Extending Compatibility Between LabVIEW and NI Drivers with Addon Support
(2,981 Views)
Thank you all.
(2,973 Views)
