Multifunction DAQ
daqmx missing vi after update
i am using Labview 2009 and i had to recently buy a NI PCIe 6321 board.
To have the board running i updated NiDaq to version 9.7.5. Communication was ckecked to be ok with MAX.
Now i have a small vi which i used to control a 6009 usb board which does not find anymore some simple subvi like daqmxread.
I can not locate these subvis on the disk anymore.
Would it be due to the fact that NiDaq 9.7.5 is not supported by Labview 2009.
Should i reinstall an older version of NiDAq ?
Thanks for your help
(3,776 Views)
You went 1 version too far.  Uninstall DAQmx 9.7.5 and install 9.7.
Because that 9.7.5 does not support LabVIEW 2009, your LabVIEW install lost its DAQmx support VIs.  It is that simple.
GCentral
(3,774 Views)
thanks for the fast answer.
My OS is windows 7/32 bits: is DAQmx 9.7 compatible ?
Otherwise which version may work for my OS and my board ?
Laurent
(3,768 Views)
If you are keeping with LabVIEW 2009, then go with DAQmx 9.7.
GCentral
(3,765 Views)
