Hi, I'm using an S series PCI 6115 at high AI sampling rate (10 MS/s), in conjunction with other NI devices. The acquisition is set in pretriggered mode, so I use a digital edge reference trigger. I need to independently control each channel trigger. It could be done using analog triggering mode, but this is not appropriate for my application, where I have to measure also baselines, which do not give analog trigger. The precise timing is fundamental and this request excludes analog triggering, as well. I don't know how to obtain 4 independent trigger marks (digital edge reference), one for each channel, in order to extract the right data sets(pre/post trigger), for uncorrelated inputs.
In short, I want to use my 6115 as a set of 4 independent ADCs (as presented by the NI S series description), each channel with its own gain and (digital) trigger. The limitation to a common clock for all 4 inputs (due to the pipelined ADC) is fine to me. For compatibility between different boards I'm using DAQmx (cannot use traditional NIdaq, unfortunately..) with LabView, as first approach, but a C code solution would be fine, too. Thanks for any suggestion,
Mihai
