Multifunction DAQ
continuous data aquisition of multiple channels
Hi!
I am acquiring data from many sensors. For my application I need continous data over a period of time.  I tried using daq assistanct with continuous data option. But, I failed to acquire the data because of buffer overflow. Presently I am using NI6221 to read 1000 samples from each channel with a sampling rate of 5000. I tried earlier posts also. But couldn't solve the problem...perhaps because I do not have deep knowledge of Labview. Any help would be greatly appreciated. Thanks in advance.
rsd
PS: labview program I tried last time is attached.
(2,817 Views)
Hi Mr rsd,
 should try to increment the number of sample to read. Set it to 10k and say me if it works.
Regards
D. Beninato
(2,797 Views)
Hi!
Thank you for suggestion, even if it takes me nowhere. I have sampling rate of 5K and reading 10k samples doesn't make any sense here. I solved this issue by using daq mx (instead of daq asssitant).
Thank you again.
rsd
(2,779 Views)
