Hey Claudio,
I have attached the examples saved in LabVIEW 7.0.
Also, if you are looking for a pulse measurement, I would check out the following shipping example.
Help>>Find Examples
Browse>>Browse According To>>Task
Hardware Input and Output>>DAQmx>>Counter Measurements>>Period or Pulse Width>> Meas Dig Periods-Buffered-Continuous-High Freq 2 Ctr.vi
This would be DAQmx, but it is really easy to use, and provides the output already formatted into seconds for you. You could use my examples as a guide and modify them for using this example and you should be all set.
Let me know if you have any problems getting this to work.
Justin T.
