07-04-2012 04:59 AM
Hi All,
I want to connect a PCI 6250 card to the laptop. Is there any way I can do it?
Is there any USB equivalent for it?
Thanks in advance,
Solved! Go to Solution.
07-04-2012 08:38 AM
The USB equivalent would be the NI USB-6351 since the 62xx USB devices are scheduled for obsolescense.
Christian
07-04-2012 09:21 AM
Thanks Christian, for your reply.
Actually, I will be using this DAQ for the first time. Can you please suggest a method to interface an SCSI 68 pin to the USB 6351? Are there SCSI ports already available (as in PCI 6250) or do I have to put additional connectors?
Khalid
07-05-2012 02:08 AM
I assume you mean SCB-68 and not SCSI 68. The USB-6351 has a direct PinOut via Srew Terminals.
Christian
07-05-2012 03:40 AM
No I was hoping to connect a device which has an SCSI 68 pin-out. Previously, I used to connect the device to my computer by using a PCI 6250 card and an adpater(http://h30094.www3.hp.com/product/sku/1780665/mfg_partno/F2N1066-03-T&jumpid=in_r3924_us%2Fen%2FSASS...)
Any ideas ?
07-05-2012 04:00 AM
As I said the USB-6351 has Srew Terminals, so there is no VHDCI (like your 6250 has) or SCSI adapter necessary.
Christian
