Multifunction DAQ
connect TPC-2206 to cDAQ 9189
Dear all,
I was wondering if someone has tried to connect a cDAQ module on a touch panel, such as TPC-2206. I have a cDAQ 9189. The DAQmx version currently installed on my host computer and the TPC-2206 is the 18.0 and I use Labview 2015. Basically, what I would like to do is to use the TPC-2206 to start and monitor a VI acquiring from the cDAQ that saves data onto my host computer.
Can you suggest the documentation to complete such a task?
thanks in advance,
Valeria
(1,970 Views)
Hi Valeria,
Some time ago a user asked a question similar to yours, and was told to refer to this document.
As old as it is, I hope it may help you.
Kind regards,
Alessia
(1,944 Views)
Dear Alamanna,
Unfortunately, some of the links that are mentioned in the article are not working anymore.
(1,938 Views)
Hi Valeria,
I'm aware of it, after all the TPC-2206 is a legacy product and not much documentation is available. I can suggest you to refer to the getting started guide and to the user manual.
Alessia
(1,925 Views)
