04-08-2019 04:24 PM
Dear all,
I was wondering if someone has tried to connect a cDAQ module on a touch panel, such as TPC-2206. I have a cDAQ 9189. The DAQmx version currently installed on my host computer and the TPC-2206 is the 18.0 and I use Labview 2015. Basically, what I would like to do is to use the TPC-2206 to start and monitor a VI acquiring from the cDAQ that saves data onto my host computer.
Can you suggest the documentation to complete such a task?
thanks in advance,
Valeria
04-09-2019 08:34 AM
Hi Valeria,
Some time ago a user asked a question similar to yours, and was told to refer to this document.
As old as it is, I hope it may help you.
Kind regards,
Alessia
04-09-2019 08:49 AM
Dear Alamanna,
Unfortunately, some of the links that are mentioned in the article are not working anymore.
04-10-2019 02:12 AM
Hi Valeria,
I'm aware of it, after all the TPC-2206 is a legacy product and not much documentation is available. I can suggest you to refer to the getting started guide and to the user manual.
Alessia
