Multifunction DAQ
chirp signal with ni pci 6259
I want to generate a chirp signal with NI PCI 6259 in interval frequency [10KHz-200KHz]. Would you please tell me can I use NI PCI 6259 to generate this chirp signal. Thank you
(3,311 Views)
The update rate is 2.86 MS/s which is 10 times the maximum frequency so it should be okay.  This document might also help you.
h_baker
(3,286 Views)
