Multifunction DAQ
can any module provide 120Kv isolation between input and output
hi,
i have one problem that i want to take a data from a system into my pc. but i want  120Kv isolation between the system and pc and if possible between channels also.
(3,068 Views)
National Instruments has several boards which provide isolation including the PCI-6230 Isolated M Series card, which is rated for "60 VDC continuous bank isolation, 1,400 Vrms/1,950 VDC channel-to-bus isolation withstand for 5 s".
Unfortunately there are no modules which provide the level of isolation you desire for your application.  I do know of any boards (National Instruments or otherwise) that provide 120 kV isolation.
Jennifer O.
(3,052 Views)
