03-11-2015 10:49 AM
I just started using USRP to collect some data and using the ethernet to transfer data into the laptop RAM and then write to the txt file. However, the sampling rate is high and the data size collected is kind of limited by the RAM size. Don't know any DAQmx device and package can help me logging more data in a more stable way (hopefully write the data directly into the hard drive).
However, I searched the website that no DAQmx package can now support the USRP. Don't know whether some DAQmx device can be connected with USRP to tackle this problem.
many thanks
Chen
03-13-2015 07:07 AM
Hi Chen,
DAQmx devices can run up to a maximum rate of MS/s, however Radio Frequency data is collected at a rate much beyond this, on the order of 10's if not 100's of MS/s. Because of this no DAQmx device will be able to aid in tranfersing data.
