I have a load cell from Transducer Technologies: LBO -500. The specs for the load cell are as follows:
Rated Output (R.O.): | | 2 mV/V nominal |
Rated Output (R.O.): 2mV/V nominal
Terminal Resistance: 350 ohms nominal
Excitation Voltage: 10 VDC
Safe Overload: 150% of R.O.
I have a cRIO 9074. I also have 2 analog input modules NI 9219 & NI 9237.
My question is which is the appropriate module that I need to use for this application. Also, what code do I need to use in order to get the reading from the load cell.
I am new to DAQ/Labview.... please bare with me.
I also have one more stupid question. I need to get data from about 14 to 15 strain gauges. I will be have around 4 strain gauge rosette setups. I am assuming I will have be using 1 strain gauge per channel. What is the suggested AI module for this application.
Thank you
Pritesh
