Multifunction DAQ
cDAQ-9188
cDAQ-9188 failed when Max run selftest - not actived. Ping IP address is OK, Max can see sub boards, but it doesn't pass selftest. checked power led is lighting, status and active leds are dark. ethernet port is lighting.
It was running OK before. After switch power off and on, the 'active' led still keep dark.
Is this means this module need change?
Thanks!
Message 1 of 1
(3,207 Views)
